I have created a survey and i want the report to still show all the options as part of the report, but only show a check box in certain locations for the items selected in multiple choice and single choice items. It is not working and I'm not sure if i just am not writing the formula correctly in the report or if there is a step I am missing somewhere. I attached the form and report (the report doesn't have formulas everywhere since i just wanted to see if i could get it to work)
Hi Sean Nagy I am attaching here a new version of your template. I was able to add the checkboxes as shown below.
I think there are two issues causing your errors: function name and field names.
Function names: You are using the function checked, which I replaced with selected*. We are about to add the checked function into the software but it is not available just yet. We are hours away from it...
Please note that we will updating the selected and checked functions today. Stay tuned to new announcements in our blog.
Field names: The name in your XLSForm is Flow_Condtions not Flow_Conditions
In the attached template you will also note that I replaced your curly quotes (”Dry”) to straight quotes ("Dry"). I was able to get things to work with your original curly quotes, but to avoid issues with the parser in the future, I would go with straight quotes.
Thank you, that and the update were very helpful. Is there a page or list of all the different report template syntax's out there?
Hi Sean,
Feature report templates—Survey123 for ArcGIS | Documentation documents the syntax.
@IsmaelChivite how do you get the check boxes to format as blue boxes? When I pull a multiple select question into a report it’s just a white box. Is there something you can do to format these, so you do it through html, etc? Thanks.
Hi @Blevins_Mark I'm wondering the same. Any chance you figured out a solution?
sorry never have figured this out.
