Hello all,
I used ArcGIS for AutoCAD plug-in, and i edit the attribute data and create new fields, can I export this data to ArcGIS? and how can I do that?
Thank you
If you have created data in ArcGIS for AutoCAD as Local Feature classes which I assume you have done because you have added fields and modified their values, then ArcGIS desktop will directly read the .DWG file you have created as a container of attributed features classes without doing anything. Just open up the file in ArcGIS Desktop and you will see that your feature classes are there ready to use as if they were in a File Geodatabase or shapefile you can easily copy them to another GIS dataset using COPY FEATURES, FEATURECLASS TO FEATURE CLASS, APPEND, MERGE etc... or just use them in your map.
