I've been able to successfully invoke Survey123 from Collector and Trek2There from Survey123, but can't find any documentation to invoke Collector from Survey123. Is this possible and if so what is the html link to do it?
Brent
Hi Brent,
The Collector App URL specification is at GitHub - Esri/collector-integration: Multi Language repository that contains documentation and sample code for creating … - you would create a link similar to what you did with Trek2There in Survey123.
Perfect!!! Thanks James
Hi James, Another quick question, is it possible to write a value to a feature layer in Collector when using the Collect app URL?
It doesn't look like it supports it right now; take a look at Add create new feature with fields pre-filled (for example to use with workforce) · Issue #13 · Esri/collector-integrati…
