I have some custom models built to assist with the loading of events for roads & highways using the Append Events tool from the Location Referencing Toolset. This was working beautifully in ArcMap 10.4.1 until I updated to 10.5.1. I've attempted removing the append tool and re-adding it to the model and reconstructing the parameters, but nothing seems to work. The Field Mappings variable as a parameter for the model will no longer update the field names dynamically based on the input and output tables it is fed. I can get around this by editing the tool and specifying the field map tables within the variables while in the model's editing window, but this nearly defeats the purpose of the "custom" nature of the model and slows down the operation tremendously.
Curious if anyone else has seen this for other field mapping variables and if there is a fix or new setting in the updated version that I am not aware of.
