I am trying to do an "export Map image" from my own Base map service (cached) using ArcGIS Rest Api.
If i use an ArcGIS Online service I get back an image as you can see here:
https://services.arcgisonline.com/arcgis/rest/services/World_Imagery/MapServer/export?bbox=-7357068.9783%2C2085124.2274%2C-7357010.7117%2C2085077.2672&bboxSR=&layers=&layerDefs=&size=&imageSR=&format=png&transparent=false&dpi=&time=&layerTimeOptions=&dynamicLayers=&gdbVersion=&mapScale=102400&rotation=&datumTransformations=&layerParameterValues=&mapRangeValues=&layerRangeValues=&f=html
But when I try to use my own Base Map service and do an export map image using the exact same parameters i use using AGOL basemap service, I get a blank response. no error, just blank
We create the cache using the AGOL, GOOGLE option from ArcGIS Pro.
Does anyone has any idea why i get a blank result.
Diego Llamas
Hi Robert,
Basically we are creating a massive appraisal project that send information to the citizen by email with photo.
That photo is the box, we tried esri service but we notice a displacement with the planimeter object is significant. Also the image service that we have has a much better resolution if we want to show 1:282 scale with esri service it really bad. . Also this aerial photo is from the agenci and we want the citizens receive official information from the agence.
Diego
Diego,
Sorry to ask this question but is the bounding box you are using in your request should that extent actually have data in your cached service. Esri's service covers the globe and I am not sure where that bounding box is for but would in be covered by your service?
Hello Robert,
Yes it is.
But is your cached service in WKID 102100 or a local Puerto Rico projection?
