import arcpy #User defines tract number: tract=raw_input("Enter census tract number:") mxdPath="C:\\Path\\To\\Map.mxd" mxd=arcpy.mapping.MapDocument(mxdPath) #use "CURRENT" if running in ArcMap Python Window or as a tool #Get Lyr Files allLyrs=arcpy.mapping.ListLayers(mxd) for lyr in allLyrs: if lyr.name=="Target Tract": #must be one and only one layer called "Target Tract" in your mxd's TOC targetLyr=lyr #if tract number is stored as a number use this line: (and remove the other one) targetLyr.definitionQuery='"Tract_Num" = '+str(tract) #change Tract_Num to name of tract field #if tract number is stored as a string/text use this line: (and remove the other one) tractsLyr.definitionQuery='"Tract_Num" = \''+str(tract)+'\'' #change Tract_Num to name of tract field cursor=arcpy.SearchCursor(targetLyr) for row in cursor: density=row.DP0010001/row.sq_mile_1 #Get layout elements: elemList=arcpy.mapping.ListLayoutElements(mxd) #Find title element: for elem in elemList: if elem.name=="Title": #Make sure you manually set the Element Name to "Title" (see attached screenshot) titleElem=elem #Edit text: titleElem.text="Census tract: "+str(tract)+" - Density: "+str(density) #zoom to selected features df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0] df.extent = targetLyr.getExtent(True) mxd.save() #remove this line if you're using "CURRENT" MapDocument arcpy.RefreshActiveView() del mxd, df, row, cursor, lyr, targetLyr, allLyrs print "executed successfully"
#Edit text: titleElem.text="Census tract: "+str(tract)+" - "Density: "+str(density) mxd.save() del titleElem, mxd
cursor=arcpy.da.SearchCursor(lyr) for row in cursor: #there should only be one row in your layer density=row.density del row,cursor mxd = arcpy.mapping.MapDocument("C:\\Path\\To\\Map.mxd") #Get layout elements: elemList=arcpy.mapping.ListLayoutElements(mxd) #Find title element: for elem in elemList: if elem.name=="Title": #Make sure you manually set the Element Name to "Title" (see attached screenshot) titleElem=elem #Edit text: titleElem.text="Census tract: "+str(tract)+" - Density: "+str(density) mxd.save() del titleElem, mxd
#user selects tract, Select by Attribute tool runs arcpy.MakeFeatureLayer_management("plano_tract", "plano_tract_lyr") arcpy.SelectLayerByAttribute_management("plano_tract_lyr", "NEW_SELECTION", "\"Tract_Number\" = "+ tract) arcpy.CopyFeatures_management("plano_tract_lyr", "plano_tract_select") #add field arcpy.AddField_management("plano_tract_select", "density", "DOUBLE") #calculate field arcpy.CalculateField_management("plano_tract_select", "density", "[DP0010001] / [sq_mile_1]", "VB", "") print "executed successfully" #zoom to selected features df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0] lyr = arcpy.mapping.ListLayers(mxd, "plano_tract_select", df) [0] df.extent = lyr.getExtent(True) arcpy.RefreshActiveView() print "zoomed to layer"
import arcpy mxd = arcpy.mapping.MapDocument("C:\\Path\\To\\Map.mxd") #Get layout elements: elemList=arcpy.mapping.ListLayoutElements(mxd) #Find title element: for elem in elemList: if elem.name=="Title": #Make sure you manually set the Element Name to "Title" (see attached screenshot) titleElem=elem #Edit text: titleElem.text="This is the Title!" mxd.save() del titleElem, mxd
import arcpy fc="C:\\Path\\To\\FeatureClass.shp" cursor=arcpy.SearchCursor(fc) for row in cursor: if row.Field1=="Taret": #i'm not sure how you wanted to pick a record, but this would find where Field1 is "Target" targetInteger=row.Field2 #change 'Field2' to your integer data field break #ends for loop titleText="This is Title number: "+str(targetInteger) del row,cursor #Then add the code above to edit the title element in the mxd.
