I am working with WAB 2.6 and want to close a widget panel when the selection in the map is changed. I can see the map.on("selection-change") code in some other question samples but don't see anything about it in the API 3.23 reference under map events. Can someone tell me the syntax for this function, where it goes and what needs to be defined in order to use the event handler? Thanks, cob
