It's possible to recreate/import a survey from the mobile app to Survey123 Connect? Maybe someone just deleted the entire survey from the "My Survey Design" Folder, but it still available in my Survey123 mobile app.
Thank you for any help
You can also recover the XLSForm by navigating to the 'My Surveys' folder on your device. For instance, if it was downloaded to the field app on a Windows machine, the path would be C:\Users\<username>\ArcGIS\My Surveys\<survey>.
Here, you should find a esriinfo file which will contain the XLSForm within it.
Hi Cristian,
If you are the owner of the survey, all surveys that have been published with your account/username should be available for downloading via Survey123 Connect once logged in.
Another thing to check for is a folder for the survey in the My Content section of your ArcGIS Online Organization. If the folder does exist, please make sure all layers, views, and a form are present within it.
Best,
Brandon
