Is it possible to default an annotate image question to the Map option? I want to have a image of the map attached to every form i submit
Hi Paul. Unfortunately it is not possible to initialize the annotate question with an interactive map, but you can initialize it with an image of your choice.
This may work for you:
More info at https://community.esri.com/groups/survey123/blog/2017/10/09/smart-skething-in-survey123-stroke-by-stroke
Thanks Ismeal i want to be able to submit a location overview at a specific scale for each survey but it looks like this can only be done manually at the moment so. I think this may be a useful feature. I can think of a few applications myself i may log it as an idea.
It is possible now in the mobile app by setting the esri style to method=map. However, it doesn't work on the Web Form. Could the Survey123 dev team please make it available on web form?
Hi Jack, do you have an example workflow for this?
