I am having a problem enabling an enterprise geodatabase. When I try to run the tool, the log shows that it goes through a bunch of database steps successfully, and then it says:
[Thu May 18 09:59:58 2017] Error creating GDB_Tables_Last_Modified table... [Thu May 18 09:59:58 2017] ERROR Creating Geodatabase tables, Error = -511,EXT_Error = 0,EXT_ERROR1 = Database user name and current user schema do not match.,EXT_ERROR2 = ,
The database folks assure me that the database is setup per the instructions here: http://desktop.arcgis.com/en/arcmap/10.3/manage-data/gdbs-in-sql-server/setup-geodatabase-sqlserver.htm#ESRI_SECTION1_0CB5A7EBA7EB4F69AA7180F0FA84779E
Can you tell what the problem might be from this error?
How do I check what the schema name is? the user name is definitely sde.
Based on the error message there appears to be a mismatch of the DB name and schema in SQL Server. Does the username and schema match in SQL Server? i.e. User Name = SDE and Schema = SDE?
You may also want to review this link: How To: Create an SDE schema geodatabase using the Enable Enterprise Geodatabase geoprocessing tool in SQL Server It shows you where to check if the schema/username matches - look at Step 2.
1. Make sure set SQL Server database options READ_COMMITTED_SNAPSHOT and ALLOW_SNAPSHOT_ISOLATION to ON. You can check the two options by right clicking on the database > Properties > Options.
2.You can check the schema of the user by following steps:
In SSMS, Security --> Logins --> Right click on the user --> Properties --> User Mapping --> make user that user name and default schema match.
3. Make sure user have, at a minimum, the following privileges: CREATE FUNCTION, CREATE PROCEDURE, CREATE TABLE, and CREATE VIEW.---------------------------------------------------------------------- Set up an enterprise geodatabase in SQL Serverhttps://desktop.arcgis.com/en/arcmap/latest/manage-data/gdbs-in-sql-server/setup-geodatabase-sqlserver.htm ----------------------------------------------------------------------
Both the username and default schema are sde. And those other options are both set to TRUE. I am told by the SQL server folks that sde is the administrator so it has all those privileges.
Yes, they are both sde
In SSMS, right click on the database -> properties -> permissions -> click on sde user -> effective and please confirm which permissions are granted.
I would recommend opening a technical support case to have an analyst look at this in more detail. It would also be good to have the DBA available for calls.
OK, thank you. I had reached out to my ESRI rep last week and not heard back.
There is a huge list. I have confirmed the four you mentioned are in the list.
