has the repeat's behavior been modified in the latest update of the Connect? - "edit and resend" for submitted surveys displays all records in the repeats, but doesn't allow for either editing or deletion (the delete btn is missing from the repeats); it does allow to add new records though.
"esri:parameters" column is set to "query allowUpdates=True" for all repeats in the survey.
We didn't have that problem in the previous versions.
Thank you.
