Hi all,
I am using this link and https://survey123.arcgis.com/?portalUrl=https://gispublic.waterboards.ca.gov/portalhttps://survey123.arcgis.com/?portalUrl=https:%2F%2Fgispublic.waterboards.ca.gov%2Fportal%2F
I keep getting survey error code 11 (Not Found). I am not too sure why.
Any help us welcome.
Thanks Alex,
Based on your and Jordan's feedback off-thread, it also appears that this has been resolved for the next release of Survey123.
Hi Alex,
Where are you getting the error code? The second URL in the post appears to function correctly.
James, I am getting the error after i hit "approve"
I get this. Everyone in my organisation is getting this error.
Thanks for the detail. Could you open the Developer tools of your browser and view the Console? Also, od you know if any settings have been made in the 'Allow Origins' Security setting (see Restrict cross-domain requests to your portal—Portal for ArcGIS (10.7) | ArcGIS Enterprise )? The most often cause for this error on login is a cross domain error (e.g., giving the Survey123 website permission to use any files on the portal, which is separate from the login process).
No settings have been made in "AllowOrigins"
In console I get the following
In Network I get this:
Dan,
I am currently running into this exact issue, could you give a little more detail to which CORS headers you removed or changed and where they existed in the portal/server sites.
Thanks!
Having the same problem with the headers, how did I remove them? Thanks
