I created a project with the MapViewr model of AppStudio for arcgis. When clicking (in .exe) on a button that opens a file an error message appears to me: no application is installed to allow opening of this type of link (qrc).
Hi Stephen ,
My problem is solved thanks to your help .
Thanks.
2018-03-01 5:24 GMT+01:00 Stephen Quan <geonet@esri.com>:
GeoNet <https://community.esri.com/?et=watches.email.thread>Re: problem when clicking a button in the executable of a projectreply from Stephen Quan<https://community.esri.com/people/SQuan-esristaff?et=watches.email.thread>in AppStudio for ArcGIS - View the full discussion<https://community.esri.com/message/754065-re-problem-when-clicking-a-button-in-the-executable-of-a-project?commentID=754065&et=watches.email.thread#comment-754065>
Ikbel,
In my previous answer, I supplied a complete working code snippet.
Please use it in a standalone app with a `readme.txt` resource.
The code snippet explains how to copy from resource (i.e. source) to file system (i.e. dest) and opens the file.
Stephen
Hi Stephen,
I think you understand my problem exactly. I want to explain more.
Well I worked with the AppStudio_x64_2_1_19 version.
I modified the homepage according to my needs which are two buttons one
opens the gallery which is the same one of you and the other opens such
type of file (.mxd, .doc, .txt, ...).
Everything works fine when I click on the Execute button of Appstudio for
arcgis desktop, the problem is in the. exe got after generating the
application, the primer button starts and opens the gallery but the second
does not open the file and an error message appears to me: no application
is installed to allow the opening of this type link (qrc).
can you explain to me more how to use the FileFolder component to copy the
files from a resource to a disk ( the absolute path does not work contrary
to the relative path).
2018-02-28 5:22 GMT+01:00 Stephen Quan <geonet@esri.com>:
GeoNet <https://community.esri.com/?et=watches.email.thread>Re: problem when clicking a button in the executable of a projectreply from Stephen Quan<https://community.esri.com/people/SQuan-esristaff?et=watches.email.thread>in AppStudio for ArcGIS - View the full discussion<https://community.esri.com/message/753697-re-problem-when-clicking-a-button-in-the-executable-of-a-project?commentID=753697&et=watches.email.thread#comment-753697>
Hi Ikbel, what you're describing is actually by design.
When you create and run an app from within AppStudio Desktop, all your source files both your .qml, .txt and .doc files resides on disk. You can referred to them with relative references which is why you can open .txt and .doc files with relative links in your app since your app will translate the relative references to absolute references to files to your disk as it opens.
However, the trap is, if you build your app using App Make, all your source files will be compiled and deployed with your app as a Qt Resource File (i.e. qrc). Most of Qt's components, will recognize both relative references to disk or Qt Resource File indifferently. For instance, if your app has .png images, you can use the Image component to display them.
However, if your app is wanting to supply a relative reference to an external process, i.e. for Windows to open, you need to use the FileFolder component to copy the files from a resource to a disk. If you don't, Windows will not have a clue what to do.
<SPAN class="keyword token">import</SPAN> QtQuick <SPAN class="number token">2.7</SPAN> <SPAN class="keyword token">import</SPAN> QtQuick<SPAN class="punctuation token">.</SPAN>Controls <SPAN class="number token">2.1</SPAN> <SPAN class="keyword token">import</SPAN> ArcGIS<SPAN class="punctuation token">.</SPAN>AppFramework <SPAN class="number token">1.0</SPAN> App <SPAN class="punctuation token">{</SPAN> id<SPAN class="punctuation token">:</SPAN> app width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">400</SPAN> height<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">640</SPAN> Button <SPAN class="punctuation token">{</SPAN> text<SPAN class="punctuation token">:</SPAN> <SPAN class="token function">qsTr</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Copy and Open"</SPAN><SPAN class="punctuation token">)</SPAN> onClicked<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> dest<SPAN class="punctuation token">.</SPAN><SPAN class="token function">removeFile</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"readme.txt"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> dest<SPAN class="punctuation token">.</SPAN><SPAN class="token function">copyFile</SPAN><SPAN class="punctuation token">(</SPAN>source<SPAN class="punctuation token">.</SPAN><SPAN class="token function">filePath</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"readme.txt"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> dest<SPAN class="punctuation token">.</SPAN><SPAN class="token function">filePath</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"readme.txt"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> Qt<SPAN class="punctuation token">.</SPAN><SPAN class="token function">openUrlExternally</SPAN><SPAN class="punctuation token">(</SPAN>dest<SPAN class="punctuation token">.</SPAN><SPAN class="token function">fileUrl</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"readme.txt"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> FileFolder <SPAN class="punctuation token">{</SPAN> id<SPAN class="punctuation token">:</SPAN> source url<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"."</SPAN> <SPAN class="punctuation token">}</SPAN> FileFolder <SPAN class="punctuation token">{</SPAN> id<SPAN class="punctuation token">:</SPAN> dest path<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"~"</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Hope that makes sense.
Thanks Tina ,
Good I detail you my problem.
I created an application with appstudio for arcgis whose first interface
has buttons each of them opens a file.
when i run the appcation from Appstudio for arcgis everything works fine
and by clicking the buttons the files open.
my problem is that after the generation of the application and executing
the .exe the buttons do not work and the action of opening the files does
not work and an error message appears to me: you will need to a new
application to open this .qrc element.
2018-02-15 19:56 GMT+01:00 Tina Jin <geonet@esri.com>:
GeoNet <https://community.esri.com/?et=watches.email.thread>Re: problem when clicking a button in the executable of a projectreply from Tina Jin<https://community.esri.com/people/TJin-esristaff?et=watches.email.thread>in AppStudio for ArcGIS - View the full discussion<https://community.esri.com/message/750853-re-problem-when-clicking-a-button-in-the-executable-of-a-project?commentID=750853&et=watches.email.thread#comment-750853>
reply from Tina Jin
Hi Ikbel,
Are you using Cloud Make tool to create a standalone Map Viewer app on Windows platform? I was not able to reproduce your issue. Here are my steps,
I would call Esri technical support to troubleshoot the issue.
Tina
Hi Tina thanks for your question,
I created a Map Viewer app using AppStudio Desktop. when I execute it from Appstudio everything works very well but after having made the generation from appstudio of arcgis on line the buttons (which open files) do not work and a message appears to me (no application is installed to allow the opening of this type of link (qrc)).
Thank you for asking your question in our Geonet community. I need more information about your issue. When you say "created a project" do you mean created a Map Viewer app using AppStudio Desktop or AppStudio Website. What button have you clicked on? Do you mind providing a screenshot of the error message?
duplicate of https://community.esri.com/thread/209630-problem-when-clicking-a-button-in-the-executable-of-a-project
