//this should allow the user to clear grid and store function clearQuery() { //clear my graphics map.graphics.clear(); //create an empty store and then bind to grid var emptyCells = { items: "" }; var emptyStore = new dojo.data.ItemFileWriteStore({data: emptyCells}); grid = dijit.byId('grid'); grid.setStore(emptyStore); }
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/> <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9" /> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title>Display Find Task results in Dojo DataGrid</title> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.8/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.8/js/dojo/dojox/grid/resources/Grid.css"> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.8/js/dojo/dojox/grid/resources/claroGrid.css"> <script type="text/javascript"> dojoConfig = { parseOnLoad:true } </script> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } </style> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.8"></script> <script type="text/javascript"> dojo.require("esri.map"); dojo.require("dojox.grid.DataGrid"); dojo.require("dojo.data.ItemFileReadStore"); dojo.require("esri.tasks.find"); dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("dijit.form.Button"); var findTask, findParams; var map, startExtent; var grid, store, emptyStore; function init() { dojo.connect(grid, "onRowClick", onRowClickHandler); //Create map and add the ArcGIS Online imagery layer startExtent = new esri.geometry.Extent({"xmin":-9267533.641224435,"ymin":5225262.235659762,"xmax":-9243914.599484349,"ymax":5232026.912662991,"spatialReference":{"wkid":102100}}); map = new esri.Map("map", { extent: startExtent}); var streetMapLayer = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"); map.addLayer(streetMapLayer); //Create Find Task using the URL of the map service to search findTask = new esri.tasks.FindTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/TaxParcel/TaxParcelQuery/MapServer/"); //Create the find parameters findParams = new esri.tasks.FindParameters(); findParams.returnGeometry = true; findParams.layerIds = [0]; findParams.searchFields = ["OWNERNME1","OWNERNME2"]; findParams.outSpatialReference = map.spatialReference; dojo.connect(map, 'onLoad', function(theMap) { //resize the map when the browser resizes dojo.connect(dijit.byId('map'), 'resize', map,map.resize); }); } function doFind() { //Set the search text to the value in the box findParams.searchText = dojo.byId("ownerName").value; findTask.execute(findParams,showResults); } function showResults(results) { //This function works with an array of FindResult that the task returns map.graphics.clear(); var symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([98,194,204]), 2), new dojo.Color([98,194,204,0.5])); //create array of attributes var items = dojo.map(results,function(result){ var graphic = result.feature; graphic.setSymbol(symbol); map.graphics.add(graphic); return result.feature.attributes; }); //Create data object to be used in store var data = { identifier: "PARCELID", //This field needs to have unique values label: "PARCELID", //Name field for display. Not pertinent to a grid but may be used elsewhere. items: items }; //Create data store and bind to grid. store = new dojo.data.ItemFileReadStore({ data:data }); grid = dijit.byId('grid'); grid.setStore(store); //Zoom back to the initial map extent map.setExtent(startExtent); } function clearMyGrid() { map.graphics.clear(); var emptyCells = { items: "" }; var emptyStore = new dojo.data.ItemFileReadStore({data: emptyCells}); grid.setStore(emptyStore); } //Zoom to the parcel when the user clicks a row function onRowClickHandler(evt){ var clickedTaxLotId = grid.getItem(evt.rowIndex).PARCELID; var selectedTaxLot; dojo.forEach(map.graphics.graphics,function(graphic){ if((graphic.attributes) && graphic.attributes.PARCELID === clickedTaxLotId){ selectedTaxLot = graphic; return; } }); var taxLotExtent = selectedTaxLot.geometry.getExtent(); map.setExtent(taxLotExtent); } dojo.addOnLoad(init); </script> </head> <body class="claro"> <div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline'" style="width:100%;height:100%;margin:0;"> <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'top'" style="height:40px;"> Owner name: <input type="text" id="ownerName" size="60" value="Katz" /> <button data-dojo-type="dijit.form.Button" data-dojo-props='onClick:function(){ doFind();}, value:"Search"'> Search </button> <button data-dojo-type="dijit.form.Button" data-dojo-props='onClick:function(){ clearMyGrid();}, value:"Clear"'> Clear </button> </div> <div id="map" data-dojo-props="region:'center'" data-dojo-type="dijit.layout.ContentPane" style="border:1px solid #000;"></div> <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'bottom'" style="height:150px;"> <table data-dojo-type="dojox.grid.DataGrid" data-dojo-id="grid" id="grid" data-dojo-props="rowsPerPage:'5', rowSelector:'20px'"> <thead> <tr> <th field="PARCELID">Parcel ID</th> <th field="OWNERNME1" >Owner 1</th> <th field="OWNERNME2">Owner 2</th> <th field="RESYRBLT ">Year Built</th> <th field="SITEADDRESS" width="100%">Address</th> </tr> </thead> </table> </div> </div> </body> </html>
I have been trying to get this to work for a while as well. When I try your code Shreyas I get a clearMyGrid is not defined in Firebug.Any ideas?Thanks!
function clearQuery() { //clear my graphics map.graphics.clear(); //Hide Grid esri.hide(dojo.byId("grid")); }
esri.show(dojo.byId("grid"));
