Requirement: I want/need to do this using hosted feature services in ArcGIS Online
I'm just trying to do something like this with just one REST API call:
<SPAN class="keyword token">SELECT</SPAN> table1<SPAN class="punctuation token">.</SPAN><SPAN class="operator token">*</SPAN>
<SPAN class="keyword token">FROM</SPAN> table1<SPAN class="punctuation token">,</SPAN> table2
<SPAN class="keyword token">WHERE</SPAN> table1<SPAN class="punctuation token">.</SPAN>primary_key <SPAN class="operator token">=</SPAN> table2<SPAN class="punctuation token">.</SPAN>foreign_key
<SPAN class="operator token">AND</SPAN> table1<SPAN class="punctuation token">.</SPAN>attr <SPAN class="operator token">=</SPAN> <SPAN class="string token">'Value1'</SPAN>
<SPAN class="operator token">AND</SPAN> table2<SPAN class="punctuation token">.</SPAN>attr <SPAN class="operator token">=</SPAN> <SPAN class="string token">'Value2'</SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Now I'm going to explain the approach I have been following and the issue I'm facing, but maybe the approach is wrong.
Steps:
- I created a file geodatabase in ArcGIS Pro with two Feature Classes (table1 & table2)
- I created a relationship class where: table1.primary_key = table2.foreign_key
- I published it in ArcGIS Online
Then I tried to do a similar query to this one using the query related records end point from the REST API but I couldn't:
- First, I noticed that it is not possible to set the objectIds param to "*" (which I don't quite understand why) <- but I could manage it by setting all the objectIds manually.
- But the real problem I found was that in the definitionExpression param I could only use attributes from one table/layer (the related one) but not from both of them.
So, I'm not sure if the only way to solve this is programmatically by:
- First query one table to get only the OBJECTIDs that meet all the criteria established to this table
- And then use the query related records setting the objectIds to those I recovered in step 1 and set the definitionExpression to add the pending criteria (the one to filter also the data within the related table).
Is this the way to solve what I'm trying to achieve or there's some way to do it with just one API request?.
Best regards,
Raul
BTW: I also tried doing a JOIN in memory and then selecting features by attributes and it worked in ArcGIS Pro, but I couldn't publish that on ArcGIS Online
