When I submit the data and go to survey123.arcgias.com to section of data I can see my data , but if export to cell all information there. `what is wrong?
Here is the screenshot. I'm not sure why the first one disappeared.
Hi Juma,
Yes, I can see the issue you are experiencing. I'll get an issue filed to examine what's going on.
Hi James,
Hope all ok. have you managed to look at my form ? I still have the same problem.
Best regards,
Juma
Hi Charles,
Your screenshot did not come through - can you repost?
I also have this problem. Here is the screenshot:
Also, when I try to open in Map Viewer, all I get is an empty window, no map. Older surveys work properly. Also my survey has repeats, but I don't see them in the table.
You should be able to see the data on the Survey123 website. Can you provide a screenshot of what you are seeing?
I just exported to excel and it works but I cant see data on survey123 website?
What file format(s) have you tried exporting to?
