Hi there,
does anyone know why the thumbnail always disappears from my survey?
Thanks for your help...
What an easy fix. Thank you, I removed the space and the periods, and it looks like that worked.
Thanks for the additional feedback. That is strange; for the surveys that appear to be OK - were these downloaded to Connect at any point? Is there more than one thumbnail image file in the survey folder?
Jim
I have been experiencing this problem with only one of our surveys. Removing the spaces from the thumbnail image name appears to have fixed it for that survey. Thanks for this advice!
Note that other surveys appear to be OK with spaces in their thumbnail image names. Weird.
Hi Melanie
Thanks for the follow-up, that's great to hear it's working now. I'll endeavour to add to this post any info on the thumbnail filename issue if/when an update is available.
Best regards,
Hi Jim,
I removed the spaces, special characters and symbols (+ plus sign and ü umlaut) from the filename, replaced the thumbnail and published the Survey again.
Now the thumbnail stays where it should be.
Many thanks for the help!
Melanie
Hi Jack
Many thanks for the additional info. When you download your survey in Connect, does a new image file appear in the survey's folder? If so, how does its filename differ from the original?
Cheers,
Thanks for this. My thumbnail names all have spaces in them yes but no special characters. This could potentially be the issue, I will wait to hear back from you guys on whether you think this is definitely the issue. Although to add to your information, redownloading or refreshing my surveys within Connect doesn't refresh my image into connect for me. Thankfully it's not a major issue for myself in Connect my end, as long as end users can see the thumbnails (which appears to be the case) on their devices as they are colour coded for the survey type/department etc.
Jack
I have the same issue. Here is my workaround : I add the thumbnail to the Form and the Feature layer in ArcGIS Online, just like I use to do with any map or app or other content.
Hi Melanie & Jack
Melanie thanks for sharing the thumbnail image and thanks both for the additional info.
I've done some testing using your image (Stadt_für_Alle+-+Kopie.png). After publishing, the thumbnail disappears from the survey's tile in the Connect gallery. The image appears as expected in the field app, Survey123 website and ArcGIS Online items.
If I remove the spaces, special characters and symbols (+ plus sign and ü umlaut) from the filename, replace the thumbnail and publish again the thumbnail is displayed in the Connect gallery as expected. I've logged this issue in our system and will post any updates to this thread.
In the meantime, the workaround is to rename the image file and publish the survey again; or download the survey to Connect (which will refresh the local thumbnail file with the online version). Could you please give this a try and let me know how it goes?
Jack Palmer - just to assist with our investigation, does your image filename contain any spaces, special characters or symbols?
Best regards,Jim
The thumbnail image is just a basic png file. Only ~9KB in size or so. Running Connect V3.3.51 and the field app is the latest android/iOS releases. They seem to show correctly right after a recent republish in my Survey123 Portal site. However it definitely needs to be re-added everytime you republish the survey. Sometimes I will just refresh the page/app and they won't be there. It's bizarre.
Cheers
Hi Jack, Hi Jim,
what Jack describes is exactly representing my Problem: "Every time I republish/update a survey from connect, it wipes the thumbnail and I have to reupload the thumbnail and then republish again. It also appears to happen randomly more often than not".
In that case the thumbnail is neither display correct in ArcGIS, nor in Connect, the filed-app or the web app.
I'm using Survey 123 Connect Version 3.3.51.
Thanks & best regards,
Thanks for the details. Does the thumbnail display correctly in ArcGIS Online (for the feature service or Form item)?
Would it be possible to attach the thumbnail image file so I can test?
Jack Palmer and Melanie Lauffenburger - which versions of Connect and field app are you running?
I also get this behaviour. Every time I republish/update a survey from connect, it wipes the thumbnail and I have to reupload the thumbnail and then republish again. It also appears to happen randomly more often than not. And then on some devices it doesn't show the thumbnail even if you redownload the latest survey yet I can the see the thumbnail in the Survey123 online and on my Connect, or sometimes it won't load in my connect yet its working on Survey123 online and devices. The behaviour of it is completed random.
Could you please describe in more detail the behaviour you're seeing? Is the survey thumbnail not displaying in Connect, the field app or in the web app? Would it be possible to attach the image file to this post? One thing to check is the file extension - Connect requires all image files used for thumbnails to have a lowercase file extension.
Thanks & regards,
