Hallo allemaal,<\/P>
<\/P>
Ik heb zojuist de gloednieuwe Drone2Map 2.0.0 gedownload en ik ben enkele problemen of ontbrekende functionaliteiten tegengekomen. Ik vraag hier gewoon om te verifiëren dat ik niet de enige ben.<\/P>
Alle hulp wordt gewaardeerd!<\/P>
Damiano<\/P>
Afbeelding #1<\/STRONG><\/P><\/P><\/P>Afbeelding #2<\/STRONG><\/P><\/P><\/BODY><\/HTML>
Thanks Damiano.
The configuration of portal for Drone2Map 2.0 will not affect previous versions of Drone2Map.
Tony
Hi Anthony,
thank you very much. Dumps have been sent, you should be able to find them yet. I will try to replicate the error when sharing and open a ticket.
One more question: if I configure the Portal to work with version 2.0, will version 1.3.2 continue to work?
Damiano
Damiano,
For portals that are 10.7 or earlier there needs to be an additional configuration step applied to the portal in order to license Drone2Map 2.0. Please see this article for more details: https://support.esri.com/en/technical-article/000021180
We will look at adding the project name to the shared projects by default for the next release.
For the crashes, please submit your crash dumps so we can take a look. In the meantime please contact support so they can log a support case.
We will look at adding a default setting to control the CPU used by default when the app starts up for the next release.
