All,
I encountered this same problem in ModelBuilder in ArcGIS Pro 3.0 today ten years later and FYI the workaround still appears to do the job.
Joe
Thanks! This works and saved me a bunch of time!
Thanks for the assistance.. It turns out that I don't need to have a draw order field that starts at 0 every time for Tableau, it just needs to be sequential. So if I add a new field that mimics the FID field, it should do the trick.
import arcpy input = "H:/GIS_Data/TEMP_GDB.gdb/feattoline" # feature class to iterate gdb = "H:/GIS_Data/TEMP_GDB.gdb" #gdb or folder for your new table table = "JunkTable" tabpath = gdb + "/" + table arcpy.CreateTable_management(gdb,table) arcpy.AddField_management(tabpath,"ID","TEXT") rows = arcpy.SearchCursor(input) ids = [] for row in rows: if row.FID_polyfc not in ids: ids.append(row.FID_polyfc) insrows = arcpy.InsertCursor(tabpath) for id in ids: insrow = insrows.newRow() insrow.ID = id insrows.insertRow(insrow) del row del rows del insrow del insrows
