Are ESRI Workforce and Geoforms cross-compatible? That is, can one set up a geoform in which the responses populate as assignments in Workforce? Thank you, my friends!
Hi Charlotte,
Yes, you could use Geoforms to populate the assignments in a Workforce Project. Since the assignments are stored in a feature service, they can be edited and added to from any application that can edit a feature service.
If you are going to use Geoforms to populate/add assignments to the feature service, there's a few things to be aware of:
- The Workforce Web application ensures that assignments are created with the correct information; i.e. a shape and assignment type and that the other values for an assignment are also correct. By doing this through Geoforms, you would be taking responsibility for this; take a look at this doc topic for more information: Workforce schema—Workforce for ArcGIS | ArcGIS
- Duplicates and QA of assignments - make sure you have a handle on duplicates that may get created and the QA of assignments; e.g. you may have multiple users reporting the same issue and each of them would create an assignment; which would lead to duplicates.
Craig
Craig,
Thank you so much! This helped me greatly!
Craig, can you re-share the schema resource? The link is broken. Thanks!
Sure Amy, this link should work:
https://doc.arcgis.com/en/workforce/android-phone/help/workforce-schema.htm
