deleted
Sounds like you are wanting to do cascading events where one event triggers the next and so on...
When I do this in (Note: I am mainly a VB.Net programmer, a lot of differences between VB and VBA) the template/guideline/strategy I uses is this:
'Say I have 1 combo and 2 other sequentially dependent combo's or other types of controls Private Sub MyForm_Initialize() ComboBox1.Clear ComboBox1.List = funtionToPopulateComboBox1() ComboBox2.Clear ComboBox3.Clear End Sub Private Sub ComboBox1_Change() 'Combobox Change event or Updated event If ComboBox1.Value = "" Then Exit Sub 'In case value was deleted/not necessary with a listbox ComboBox2.Clear ComboBox3.Clear Dim selectedComboVal1 As String selectedComboVal1 = ComboBox1.Value Select Case selectedComboVal1 Case "Condition1" conditionFilter = "ConditionArg1" Case "Condition2" conditionFilter = "ConditionArg2" ... Case else SubToPopulateComboBox ConditionFilter,comboBox2 end select End Sub Private Sub ComboBox2_Change() 'Combobox Change event or Updated event If ComboBox2.Value = "" Then Exit Sub ComboBox3.Clear Dim selectedComboVal1 As String selectedComboVal2 = ComboBox2.Value Select Case selectedComboVal2 Case "Condition1" conditionFilter = "ConditionArg1" Case "Condition2" conditionFilter = "ConditionArg2" ... Case else end select SubToPopulateComboBox ConditionFilter, comboBox3 End Sub Sub SubToPopulateComboBox(filter,cbo as ComboBox) Select Case cbo.Name Case "ComboBox2" functionToPopulateCBO2(filter) 'filter is based on the previous ComboBox selection Case "ComboBox3" functionToPopulateCBO3(filter) End Select End sub
