Hallo iedereen, dit is sidhardha, momenteel werk ik aan netwerkanalyse in ArcMap voor het wegennetwerk van dehradun maar ik had een beetje verwarring met de gegevens, kan iemand mij alsjeblieft helpen dit op te lossen? <\/P><\/BODY><\/HTML>
Hi Sidhardha,
> ... i am working on network analysis in ArcMap for road network of dehradun ut i had a bit confusion with the data
You'll likely get better assistance if you state your problem/issue with the data more clearly. Please be as specific as you can and provide repro steps.
FYI, this tutorial may be useful: About the ArcGIS Network Analyst extension tutorial—Help | ArcGIS Desktop
Hope this helps,
Hello sir, thanks for the help. My question is that while downloading the data from openstreet map we will not find all the attributes like (oneway,FT_cost,TF_cost...)
then how we should find the data for that.
You will have to reach out to the source of where you downloaded the OpenStreetMap dataset and ask them if the dataset includes those attributes. You may want to reach out here, OpenStreetMap and OpenStreetMap Foundation.
Also sir, when performing the network analysis in arcmap some of the attributes such as (FT_COST and TF_COST) which are very important for performing the process are missing from that downloaded data(openstreet map data). Where can I have that data so that I could complete a network dataset without any error.
