I am trying to publish a survey that takes no spatial location data. I would like the Survey123 form to open only a table from the service without taking a spatial location even though it is related to a layer. Below is my work flow.
- My hosted feature service has culvert locations (spatial) that have a relationship class to their inspections (table). The relationship is built on Culvert Global ID and the inspection GUID.
- I create my Survey123 form by importing the service in ArcGIS connect. The spreadsheet has the culvert data fields and a repeat for the inspections fields.
- Then I removed some of the culvert fields, (geo point, others not needed). Then set them to read only. I also changed the bind:esri:fieldType to null so the information will not be passed back to the culvert layer.
- Add the inspection GUID field within the inspection repeat so I can pass the culvert Global ID.
- I publish the form.
- The web map I created has the culvert layer and inspection table. The culvert layer has a pop up that calls the survey123 form and passes the culvert Global ID and other fields through a URL link.
- After clicking on a culvert, the inspection form opens and I am able to enter data. However, I get a Send Error message which states “Cannot insert the value NULL into column CLVT_NM”.I was thinking the error might be because Survey123 is trying to create a new culvert. Because CLVT_NM is required it cannot create the feature.
In looking through the posts, I found one that said you can create a non-spatial form of a table if you change the layer ID to 0 for the table and the spatial layer to 1 so that the Survey123 form will use the table as the base build.
I have included the Excel form for reference.
Thank you,
Kevin
