So there is nothing worse, I find, than wanting to reuse some code you have successfully deployed in once place and not getting it work elsewhere. I'm running into this with using Search (JSAPI 3,x) in my latest custom widget for WAB 2.16.
It's a simple search with suggestions that I'm recycling. Gave it a new name and hooked it into a new service but it bombs when trying to return suggestions. This is what I'm doing, maybe someone spots my obvious mistake.
// plugged in the widget.html, I have
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>div</SPAN> <SPAN class="attr-name token">data-dojo-attach-point</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>searchWithSuggestions<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">id</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>searchWithSuggestions<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>div</SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
