ArcGIS metadata is stored in the geodatabase system tables, so you cannot store ArcGIS metadata for objects that are not registered with ArcSDE or the geodatabase. The views created through ArcGIS Desktop are database views and are not registered with ArcSDE or the geodatabase and, therefore, ArcGIS metadata cannot be stored for them.We realize this is a limitation that needs to be addressed before the admin commands are retired. At present, though, the only way to store ArcGIS metadata for a view is to create it with the sdetable command as you described.
Can anyone tell me if it is not good practice to have metadata on database views and if so please explain why?
The support analyst�??s comments were that it does not make much sense to create meta data for a view when one would have the metadata for the original data source
If that is the case what is the best practice when you need to publish a subset of data, complete with its own metadata and you�??d rather not duplicate your original database tables, to avoid redundancy in your database.We are currently in the process of publishing data until our obligations to do use under the EU INSPIRE Directive. However some of our database tables cover multiple INSPIRE Themes so we need to create views of the data. Clearly the metadata has to reflect what we are publishing, rather than what the original database contains. Besides, if we publish a view, how can we publish the metadata if the view doesn't contain any?[/URL]
Of course it is good practice to add metadata to (subsets of) your data. The things I wrote in the other thread are merely to explain to you that there is a technical issue here, that is not a bug, but requires a potential enhancement to allow storage of metadata with spatial database views.I don't agree, I think you have a legit desire, but that doesn't make it a fault of ESRI or bug in the ArcGIS for Desktop application. It is a matter of choice in where to put development effort in, and if there is a need, than ESRI is likely to full fill it at some point, see Kimberly Peter's remark.The functionality for creating database views from within ArcGIS for Desktop is relatively new, keep that in mind also.
Tim,I don't know if this is a real solution to your issue, but you might consider setting Definition Queries on your layers in ArcMap that need to be published, and save them out as stand alone layer files (*.lyr) outside the ArcMap document. You can than use ArcCatalog to create metadata for this specific layer file, which will be stored as a separate XML file next to your layer file in the folder where you stored it. Additionally, you can limit the number of visible fields in the layer properties.
I guess the issue we found was that we were trying to achieve something that was possible in the past, via a different way of working.
I guess the issue we found was that we were trying to achieve something that was possible in the past, via a different way of working. ESRI then decide they were prefer us not to use the existing way of working and stated they were going to remove it. So we switch our way of working and find we can't do what we previously were able to do. We have an ObjectID with our spatial views.
However, it seems the above will work only if the spatial type is SDEBINARY, and not if the spatial type is GEOGRAPHY or GEOMETRY. Would you be able to confirm if this is the case? If so, is this Esri would consider as part of whatever solution is implemented to deal with this issue?
ESRI is moving away from the SDE command line to create views to the new "Create New View" functionality in ArcGIS Desktop, but don't consider it a bug when the replacement function loses functionality? Not uncommon for ESRI since they did that when going from ArcInfo Workstation to ArcGIS Desktop taking around 10 years to regain automated map production.
Losing the ability to attache metadata to database views is a serious loss. There is no way for the user to know what the base feature is or what definition queries are placed on the data. Layer files are pointers to data (and symbolozation) but once you've added the layer to your MXD metadata in the .lyr.xml file is no longer associated with the MXD entry!
Kim, we recently upgraded to 10.2.2 so we're still able to create SDE views. You mentioned two years ago that the problem of metadata for views was something that ESRI planned to address before the admin commands were retired. Has it been addressed at 10.3, or if not, at 10.4?
