I am having a custom widget in which I have a select tag creating using dojo/select (Dropdown) whose items are filled dynamically from RDBMS. Note that I have several long length items in the dropdown. The issue I am facing is that when I click on the select tag for choosing option. The dropdown overlaps in my map div which is outside the parent widget. I expect it to be inside the parent widget. for this I have tried setting the max-width, but this is not adhered and reverts in overlapping of the select tag. Also, I have tried making
