I have a drop-down list with 3 values and I want to set one value to be default, I can do this but it seems no to work when the field is within a Repeater.
How can I do this within a Repeater?
Thanks.
Hi John,
Again, I am able to get this to work. See the attached sample. One thing to note is that he default must be the 'name' value of the choice, not the label.
Here is example that doesn't work.
The highlighted line is the field I am trying to set the default to "Low".
This field has an appearance of "minimal".
I'm able to set a default value for a select_one within repeat section successfully. Can you provide the example that does not work?
