I cant find where I can change the pop-up in a map display. I want to change the popup from Northing: 42 to a different field. See pic below
Hi Eric,
You can change the primary display field within the data pane. This is described here - View pop-ups—ArcGIS Insights | Documentation
You may also be interested in using the attributes tab. this is described here - Create a map—ArcGIS Insights | Documentation
let me know if this doesn't answer completely.
