Using iPAD tablet Survey123 Field app, it drains battery quickly. Please advise.
Thank you.
Hi Alex,
Are you using any external sensors or bluetooth devices connect to the iPad and used with Survey123?
What model iPad are you using, what iOs version, and also what Suvey123 app version?
How many hours per day are you able to use the iPad?
Phil.
Philip,
Thank you for your response.
iOS Version is 11.3.1, model is MF010LL/A (Ipad Air)
I tried the following combination which wielded this result.
Again, since I did not enter any information it does not save that entry, if some information is entered it will save the entry and when I open the application it will prompt me to dismiss the info or continue that survey.
Thanks for the extra information. What version of Survey123 app are you using?
And yes, for autosave to work in the survey123 app and autosave your current survey and enable autorecover if the app crashes, you need to make a least one change to the survey once it is open, if it is opened without any changes it will not be saved.
Hello Phil,
The version is 3.0 , Survey123
It seems that Survey 123 drains battery much faster than collector and field maps. What gives?
Any answer or workaround for this? We see rapid battery depletion with survey 123 using brand new rugged tablets. Way more than field maps. 4 batteries to make it through the day. Feel like being pushed to field maps although the forms are not as nice.
