Hello everyone!
I'm currently trying to calibrate stationing along a highway, but I need the stationing to be straight numbers ("54000" instead of the typical "540+00"). I have an Excel document that the correct formatting is in, and I thought I'd join it with our current stationing shapefile, but when I import it into ArcMAP, the field is automatically changed to a string. I need it to be a number field. That's the only way the calibrate tool will work. Any suggestions would be greatly appreciated!
Things I've tried:
Changing field type from ArcCatalog (which I found you can't change from text to number)
Setting the type in Excel to number
EDIT: I fixed it myself. Apparently if you save your Excel document as a .csv first, then import it, ArcMAP will automatically make the field numeric.
