I am using Survey123 Connect to create a survey. Is there a way to set up the survey to automatically insert a comma for an integer? For example, 5,000 instead of 5000 or 150,000 instead of 150000.
Hi Katrina,
It sounds like you are wanting to insert grouping separators (which can vary from country to country). These are supported with decimal questions when using the thousands-sep appearance.
Is there a way to use it on integers?
Is there? I am also wondering why this doesn't work for an integer field type.
