We are receiving an error while trying to sync updates from feature services on our 10.3.1 server. Is this an known issue? Have there been any solutions or work around implemented? The error is "Error Processing Server Request"
Carlos Porras
Clarification, the sync issue appears to happen when working with versioned data/feature services.
We get the same error message. However, the error remains even after having unregistered all feature classes and recreated the feature service.
Any thoughts on what we can do to resolve this error?
Edvin
I am also getting the error… looks like a bug. It’s being evaluated.
Thanks Don. Here is the bug info I received from support:
"BUG-000089025-Unable to synchronize edits in ArcGIS for AutoCAD if a polyline layer exists in the referenced ArcGIS for Server 10.3.1 feature service"
Do you think that a new service patch for SQL server could be the source of the error?
Are you able to delete features from within AutoCAD? The only time I get this server error is when I try to update or create features. If I delete features, I can successfully synchronize but when I try the other two, it gives me an error. My features services are set to have all capabilities enabled.
HI Jarom,
We´re also able to synchronize when we have deleted features but not when we have added or edited features.
Thank you for your inputs everyone. As Don mentioned earlier this behavior seems to occur due to defect BUG-000089025 which is being evaluated. We should note that this issue was logged specifically to syncing updates from feature services which contain Polyline geometry.
I would be curious to hear if that is the case for everyone in this thread -that would be much appreciated to help us understand the underlying issue and narrow this down further.
We´ve tried to synchronize to feature services with points and polygons as well, with the same result.
What is your best estimate for the fix of the software bug? Is that possible to estimate at this stage?
Thank you for the additional information provided Edvin, much appreciated. I will need to test this again and will update the internal notes for this defect accordingly.
As for your second question below, I am afraid it would not be possible to give an accurate estimate at this stage indeed. The public facing URl for monitoring the status for this defect is below:http://support.esri.com/en/bugs/nimbus/QlVHLTAwMDA4OTAyNQ==
Hi Christoforos,
It seems that the error is not due to AGS version at least We have tried services from 10.3.1 and 10.2.1 with the same result.
/Edvin
Further evaluation shows that ArcGIS for AutoCAD does not appear to be the source of the problem. Internal testing shows other factors. In the cases where you are having difficulty synchronizing, Can you use the ArcGIS Online viewer to edit your data? If you add your feature services to the Web Viewer and cannot edit them there, then it is more likely we have all be dealing with server issues regarding updating databases and feature services not ArcGIS for AutoCAD synchronizing services. I would be interested if this is the case or not for those having problems? dkuehne@esri.com
I can edit my feature services just fine in ArcMap as well as in ArcGIS Online's Map Viewer. I believe it is something inside of AutoCAD or the process of synchronizing in AutoCAD.
