I'm trying to load a .xlsx document (see Select.xlsxForm.png) through Survey123 Connect for ArcGIS and the message "Converting XLSform message does not disappear". (See Converting_XLSFORM.png)While the message is displayed, I looked at the C: \ Users \ xyz \ ArcGIS \ My Survey Designs directory and I can see my form here. So I close Survey123 Connect for ArcGIS and my form is listed (see form_list).When I try to publish the form, the same thing happens, the publishing processes are not finished (see publishing_AtivosVia.png), but when I look at My Content, the survey directory is ready (see publishing_Ativosvia_result.png).
Does anyone had the same problem?
Base Enterprise 10.5.1
Survey123 Connect 2.3.24
Attached Ativos_de_vias.xlsx is the form that I'm trying to load
Hi James,
I have here three machines, all of than are phisical.
1º Microsoft Windows 8.1 Pro 6.3.9600 N/A compilação 9600 - Base Enterprise 10.5.1 (Survey123 Connect for ArcGIS do not work here, but Base Enterprise 10.5.1 works fine).
Dell Precision M6800 16GB RAM, i7 [01]: Intel64 Family 6 Model 60 Stepping 3 GenuineIntel ~1300 Mhz
2º Microsoft Windows 8.1 Pro 6.3.9600 N/A compilação 9600 Image Server 10.5.1 (Survey123 Connect for ArcGIS do not work here, but Image Server 10.5.1 works fine).
Dell laptop 4GB RAM, i5
3º Microsoft Windows 8.1 Pro 6.3.9600 N/A compilação 9600 - Survey123 Connect for ArcGIS only. (Survey123 Connect for ArcGIS works perfectly).
It is a test environment, I'm using in some tests with Base Enterprise and Standalone Image Serve.
Tks
Hi Wellington,
What operating system are you using (and is this a virtualized desktop or other similar environment)? This appears to be more of an OS issue than an ArcGIS Enterprise issue. That being said, the target for Survey123 Connect are workstation-type PCs as it is an authoring client rather than server OSes.
Hi John
Thanks for your answer
I've just installed Survey123 Connect for ArcGIS on a different machine without any ArcGIS software and it worked fine, no error message.
On my first test, I had installed Survey123 Connect for ArcGIS with ArcGIS Enterprise 10.5.1 Base and behaved as in the first post.
Just to let you know, another thing that I notice, on the machine that Survey123 did not works a missing dll error was shown, as you can see below:
---------------------------Survey123ConnectforArcGIS.exe - Erro do sistema---------------------------O programa não pode ser iniciado porque está faltando api-ms-win-crt-runtime-l1-1-0.dll no seu computador. Tente reinstalá-lo para resolver esse problema. ---------------------------OK ---------------------------
Even after install the Microsoft KB that fix the dll error, Survey123 Connect for ArcGIS still do not working.
https://support.microsoft.com/en-us/help/2999226/update-for-universal-c-runtime- In Windows
Do you about any issue when Survey123 is on the same machine that a Base Enterprise?
So, my guess is, Survey123 client doen't works fine on the same Base Enterprise machine.
Wellington
Hi Wellington
I have published your survey against portal 10.5 without any issue.
Have you attempted to import the xlsx you shared and publish it as a new survey?
Also are you using Windows?
John
