Could someone please share an example of a hidden field. I can not seem to get the syntax correct. THANK YOU!
There are two main ways of hiding fields.
1. Specifying hidden as the field type (as in rows 3 and 4 in the attached Excel document). You use the bind::esri:fieldType column to specify what you want the field type to be:
2. Using the relevant column to hide a question (as in rows 5 and 6 in the attached Excel document):
Hidden fields will never be displayed in Survey123, whereas fields with relevancy set on them will be displayed if the specific condition is met.
You can check exactly what will be published in the Schema Preview within Survey123 Connect:
When using hidden questions in Survey123 forms, I notice that these fields are by default invisible in ArcGIS Pro, but visible in Survey123 Web page. Of course I could set these fields to invisible in the table section but I need to set this every time i open the feature layer in Survey123 Web page. Is it possible to have it by default to invisible?
Hi Rene,
I'm not sure what you are referring to by hidden questions being hidden by default in ArcGIS Pro - that should not be the case (and is not the case in my testing).
HI James, the added image shows the fields visibility upon adding my Survey123 Feature Layer in Pro. My hidden type questions are not visible as I want it to be. When viewing the same feature Layer in the data tab of survey123, all these hidden fields are visible
