snowcobra,Are you replacing the text inside the square brackets with the correct column names from your attribute table?You need to provide more detail on what you have tried, so we can work this outRegardsAnthony
snowcobra,First off all you will need to use a label expression (http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00s800000027000000.htm) to build up your label, along the lines of (where open,HBP,Operators and Competition are fields names): "Open: " & [Open] & vbNewLine & "HBP: " & [HBP] & vbNewLine & "Operators: " & [Operators] & vbNewLine & "Competition: " &[Competition]then you need to use maplex to position the label into the bottom left by using internal zones:http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Placing_labels_using_internal_zones/003s0000002n000000/RegardsAnthony
