Will there be an ArcGIS for AutoCAD 2016? If so, any idea on the release date?
I just updated to 2016, and I didn't think about the ArcGIS for AutoCAD breaking. The latest version on the downloads page is for 2015.
ArcGIS for AutoCAD | Download
The ArcGIS for AutoCAD 375 Release will likely be some time this winter and will include be certified for AutoCAD 2016. However the current versions seems to work just fine with AutoCAD 2016, as is.
Interesting. I tried the 2015 version, and it doesn't work with AutoCAD 2016 for me.
The install won't necessarily work but you can copy the resulting program files and use/copy them from an existing install of 2015-2013. Be sure that the OS matches and that you are using the 64bit version or 32bit version.
Alright, I think I figured it out.
Here's the error message I was getting when I started ArcGIS for AutoCAD:
I just copied the ArcGISForAutoCAD.dll from the ArcGIS for AutoCAD 350 root folder to the AutoCAD 2016 root folder, and it loads the ribbon now. I haven't tested any further than that.
