When using the buildings tool (I think it used to be called simple buildings) on the Defense Mapping Toolbar in conjunction with the sketch halo, the simple buildings tool begins to populate the spatial attributes (lzn, wid, ara) improperly. It appears to be doing it in the wrong units (supposed to be meters, I think it's doing kilometers). In addition to populating the spatial attributes incorrectly, it also uses the wrong units to distinguish point from area when it chooses the appropriate geometry to create. When the sketch halo is deactivated, the tool still malfunctions until you stop the edit session and start editing again (without the sketch halo). However, I have encountered situations where, once editing is resumed, the LZN and WID are populated, but the ARA calculation still appears to be in the wrong units, since it's almost always calculates it to 0.
When I check the Buildings Property Configuration, it still reads meters as the unit of measure, so I'm not sure where the problem is coming from.
I am using the TDS v6.1 schema, if you need to test it on something... WGS 84.
ArcGIS 10.2.2 for Desktop
ArcGIS 10.2.2 License Manager
Esri Production Mapping 10.2.2
Esri Defense Mapping 10.2.2
ArcGIS 10.2.2 Data Reviewer for Desktop
Let me know if you need additional information.
-Randy
