Hallo allemaal,
Ik probeer de google apps popup na te maken die verschijnt bij het klikken op een knop, zoals hier te zien is Google
Is er iets binnen leaflet dat hier dichtbij komt?
Een jsfiddle zou geweldig zijn!
Bedankt,
Tim
that's not really an esri leaflet question so much as a generic HTML/JS UI question.
you might check out bootstrap button dropdowns http://getbootstrap.com/components/#btn-dropdowns-single . another alternative is to write your own javascript to listen for when someone clicks on the button and programmatically display an entirely new <div>.
i'd be happy to review a fiddle if you want to give it a try and get stuck.
Those are great suggestions, I will see if I can get one of them going.
Thanks for offering help in case I get stuck. I will let you know.
My bad, I use the apps so often I forgot that not everybody does.
I have attached a screenshot of the pop-up I was talking about.
I was looking at something like this Editing feature layers | Esri Leaflet where you can click on draw a polygon and then a submenu pops up. Instead I would click on a button and a submenu with app choices comes up.
can you provide a little more information? your hyperlink just points to google.com.
also, it'd be helpful if you could show/explain what you've already tried, rather than just asking someone else to create a code sample for you from scratch.
