I need to make a hidden field only accept images. Is there a way to set the type to image even though its set to hidden?
Hi. It is not possible to make an image field hidden. Can you describe what is the use case for this?
Thanks!
Hi Ismael Chivite
The use case is that I have 2 separate surveys that I send data from one to another. The 2nd survey acts as my "edit" function which captures data from the user and sends it back to the main survey using REST. As I want to allow the user to add a picture in this 2nd survey, I need a way to send the picture via REST to the 1st survey but for it to not show (the image type) in the 1st survey as I would only show the image in the popup on my web map.
