Is there a way to programmatically activate a TOC View? Specifically, I would like to make the Snapping View visible (esri_mapping_SnappingView). Thanks!
If the id you provided would be a DockPane (ref to "activate a TOC View") then you would do the following:
DockPane pane <SPAN class="operator token">=</SPAN> FrameworkApplication<SPAN class="punctuation token">.</SPAN>DockPaneManager<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Find</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"esri_mapping_SnappingView"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>pane <SPAN class="operator token">==</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">return</SPAN><SPAN class="punctuation token">;</SPAN> pane<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Activate</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
I am not aware of any dockpane for snapping. Doesn't mean it's not there...
