I'm having problems in getting one of my aliases to work in my customized Locator:
I've adapted one of ESRI's Locator Style Templates to my needs. In doing so, I set a bunch of new aliases in the Aliases section inside grammar. Overall, it is working properly, but I'm having trouble in getting any alias with the sequence of characters .º to work, which is a common in portuguese abbreviations.
I transcribe bellow a part of my Locator Style Template defining aliases for the word "primeiro":
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>grammar</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="comment token"><!-- (...) --></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>section</SPAN> <SPAN class="attr-name token">desc</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>Aliases<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>alias_list</SPAN> <SPAN class="attr-name token">name</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>StreetNameAliases<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>alias_def</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>alt</SPAN><SPAN class="punctuation token">></SPAN></SPAN>primeiro<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>alt</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>alt</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1º<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>alt</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>alt</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1.º<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>alt</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>alias_def</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="comment token"><!-- (...) --></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
With this definition, the locator successfuly matches the input string "rua 1º de maio" to the address "Rua Primeiro de Maio" (100 matching score), but it gives no matching candidates for the input string "rua 1.º de maio"!!!
I already tried to substitute the . with the . HTML code and several other workarounds and nothing worked.
Any thoughts on what's happening and how to correct it? HELP, these Locator Style Templates are a complete madness...
geocoding geocoding locator
