I have selected a number of polygons by using select by location, 100m from a roads feature layer. After making a layer from the selection, I merged two such layers and need to populate Lat and Long fields in order to locate them with a GPS in the field.
I did it in tables and CALCULATE GEOMETRY as well as the ADD GEOMETRY tool from the tooblox.
Either way I get a long decimal coordinate that will not work at all.
I have done the same process with points and had fine luck. Only in obtaining the Centroid of a polygon is throwing me.
thanks for any thoughts.
