Hi, guys. First of all sorry for my poor english.
I need to know how to use "if" and "then" to set a value.
For Exemple:
I have a fild that need to display a value to the user:
If (totalbrocasha "greater than" 3000 then coposliberar "equal" 12)
The following expression will return 12 if totalbrocasha is greater than 3000 and otherwise, it will return 0.
if (${totalbrocasha}>3000,12,0)
You can use this expression in the calculation column of the coposliberar question.
The Quick reference—Survey123 for ArcGIS | ArcGIS is a great topic to learn all the things you can do with formulas in XLSForms.
Nice, it's works. Thank you so much.
I have one last doubt:
And if I have more arguments?
For exemple:
if totalbrocasha <= 399 then coposliberar need to be 0
if totalbrocasha >= 400 and <= 2999 then coposliberar need to be 8
if totalbrocasha >= 3000 and <= 3999 then coposliberar need to be 12
if totalbrocasha >= 4000 and <= 5999 then coposliberar need to be 18
and finally if totalbrocasha >= 6000 then coposliberar need to be 22
I've tried this way:
if(${totalbrocasha}>6000,22,if(${totalbrocasha}<=5999>=4000,16,if(${totalbrocasha}<=3999>=3000,12,if(${totalbrocasha}<=2999>=400,8,0))))
But the result is aways "0".
Nested if statements are really tough sometimes. These are a lot like what is used in attribute assistant: All methods - Attribute Assistant | ArcGIS Solutions (scroll down to additional functions). I suggest working with your statements one at a time, adding as you go. See: https://community.esri.com/thread/183208-iif-function-in-dynamic-value-table
Thank you for your help, Joe.
I've tried the solution that works for IIF function in Dynamic Value table (using 0, Null, <Null>, 00, "", [#] and "Nothing", like Jennifer Stone did).
But I still receiving only 22 or 0 as a final result.
Hi Marco,
Your evaluations for the if() functions after the first will not work - what you are trying to do would require a compound statement (i.e., ${totalbrocasha}<=5999 and ${totalbrocasha}>=4000 ). That being said, with a nested structure like this, you don't need one side of the limit - it's already taken care of by the previous statement (i.e., the <=5999 is unnecessary as you already have caught all values larger with the first evaluation >=6000 ).
Thank you so much.
