ArcGIS Maps for PowerBI: Latency/ Lag issues:
Good day to you!
Thank you for brining this to our attention. I opened the PBIX attached and confirmed that there is some latency upon opening and working with the application (specifically with the slicers). Without delving too much into it, I believe it may be with the volume of data you are attempting to process. Can you confirm the row count for this dataset?
As for the visual not loading, I did not run into this issue could you confirm that we are using the latest version of PowerBI? I am using the Aug 2020 release, and am not running into this issue.
