I downloaded the plugin through Adobe and it seemed to install correctly. However, I keep getting a black screen with no map window, nowhere to login...nothing. I have uninstalled and reinstalled the plugin multiple times and keep getting the same result. Has anyone had a similar issue or does anyone have a solution?
GREAT! Glad to hear that. Please let us know if you have any comments about the app
SUCCESS! Thanks everyone!
Hi Brian, Can you please upgrade and try again. Let us know if you still see the issue.
That's the problem. The app supports Adobe Illustrator CC version 19.2 and beyond.
I was a beta user and didn't work then. I'm on version 19.1.0
Hi Brian, are you our Beta user of the app before? What version of Illustrator are you currently using?
Dropbox - config.json
Thanks for confirming. The file size appears smaller than what I expected. Can you please attach the file here for me to take a look at it?
Running on Windows 7
This is what I have in the config folder
Hi Brian,
Sorry about the issues you are experiencing.
At first hand seems to me that some part of the installation may not have completed correctly on your machine. So can you check for a few things on your machine.
Could you please confirm if you have a config.json file installed on your machine in your users profile? In windows it should be under C:\Users\<user_name>\AppData\Roaming\m4cc\config.
If so can you please send a screen shot of what is in it?
Also wondering what is the OS and Creative Cloud version on this machine?
Madhura
