I cant see the location of survey on map although in XLSM I have geopoint .Can anyone advice?
Hi Juma,
Can you provide more details regarding where you are attempting to view your geopoint dataset? For instance, are you observing this behavior in the Survey123 field app on a phone, or using the web app?
You mentioned that you are using an 'XLSM' file, does this mean that you are attempting to utilize macros? If so, please try to use a .xls file to generate your form and see if you are able to see your geopoint reflected.
Brandon
Hi Brandon,
Thanks for your email.i am using connect to to create survey using xlsm format that will created when I click New survey. The problem I have I am using few survey and some of them ok but some not supported by survey123 . Through when I export data to excel all the data there . I have problem both with all browser and all devices so I am doing something wrong but can't find it what it is.Best regards.
Juma
Sent from my Samsung Galaxy smartphone.
Can you please share one of the XLSForms that you are encountering the issue with? You should be able to upload to this thread by using the 'Advanced Editor' link within your reply, or if you would prefer to send it to me over email, let me know and I will send you a private message with my email address.
Thanks. Can you please send me your email and I will share with you the form.
Best regards,
juma
After taking a look at your XLSForm, it appears that you are using several 'Reserved Keywords' as names for your fields. You will notice that there are several 'Validation Errors' that appear in the name column of your XLSForm, which is indicating that these names are not valid and need to be changed.
In addition, you can reference the 'types' sheet within the XLSForm which has a list of Reserved Keywords.
In your particular case, the name's causing issue are 'where', 'case', 'link', 'add', and 'name'.
Please change these names, republish the survey, and see if you are able to view the data without issue in the Survey123 website.
Ok thanks that is great tips. Will follow and let you know. I can still export all the data to excel and CSV and this section is not affected.
