Hi,I add my SVG files here, since I couldn't find how to attatch them on the original post, Jason Laferriere.comarques.svg is the original svg (only with id="x" added).comarques_mallorca_simple.svg is the final file added in SurveyConnect Media (after making some changes with InkScape).Thank you,Gabriel Garcies
Gabriel,
Try this SVG that i reworked.
I think your comarques.svg was too nested or getting confused on how far nested it was.
In Inkscape, i exported your SVG to PNG and recreated the individual paths by using "duplicate" (Edit menu) on the image and "break apart" (path menu). I then renamed the path labels with the "objects" menu and copied it over to the path in the "XML Editor" (Edit menu). Then I recolored and saved as SVG.
Hi Jason,
It works perfectly with yours.
I will try to make it the same way from now to the future.Thank you so much!Gabriel
