Could you please help me with this issue, please find below the screenshot. Also you can find in attachment the file.
Thanks in advance
Hi Alima,
The most usual reason for this error is that a question that submits a text answer (text, hidden, calculate, notes, select_one and select_multiple) is submitting text too long for the field that holds the response. I see that a few questions have had their field length set to non-default values; this must occur when a field is first created (can't be changed afterwards). I also see there are a number of calculate questions using pulldata, can you check the length of the values being extracted?
