I am looking for the following events: LayoutAdded, ElementsAdded, and ElementsRemoved events. Are these going to be in future releases of the Pro SDK?
Thank you,
Tony
These events will be added for 2.3: ElementAdded, ElementRemoved, LayoutAdded.
Thank you for bringing these events to our attention.\
Jeff
Thank you Uma! I will add this and test it out. I appreciate the advice!
Hi Tony
As a workaround you can determine when a new layout has been added by using the ProjectItemsChangedEvent like this:
ProjectItemsChangedEvent<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Subscribe</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN>args<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>args<SPAN class="punctuation token">.</SPAN>ProjectItem <SPAN class="keyword token">is</SPAN> LayoutProjectItem <SPAN class="operator token">&&</SPAN> args<SPAN class="punctuation token">.</SPAN>Action <SPAN class="operator token">==</SPAN> System<SPAN class="punctuation token">.</SPAN>Collections<SPAN class="punctuation token">.</SPAN>Specialized<SPAN class="punctuation token">.</SPAN>NotifyCollectionChangedAction<SPAN class="punctuation token">.</SPAN>Add<SPAN class="punctuation token">)</SPAN> System<SPAN class="punctuation token">.</SPAN>Diagnostics<SPAN class="punctuation token">.</SPAN>Debug<SPAN class="punctuation token">.</SPAN><SPAN class="token function">WriteLine</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Layout has been added"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Thank you for your feedback Tony! We did add a couple of new events for Pro 2.2: LayoutRemoving and Layout PausedDrawingChanged but we will strongly consider the 3 events you request for a near term release.
