Hi there,
is it possible to enable to the "Time Settings" of a Feature Service with the Python API?
Thanks for your help
Karsten
Find the solution:
def updateServiceDef(token): ''' use this to update feature service max record count ''' updateServiceDefURL = 'https://services2.arcgis.com/.../ArcGIS/rest/admin/services/.../FeatureServer/0/updateDefinition' params = { 'updateDefinition': {"timeInfo" : {"startTimeField" : "DateTimeField1", "endTimeField" : "DateTimeField2"}}, 'async': 'true', 'token': token, 'f':'json' } response = requests.post(updateServiceDefURL, data=params, verify=True)
You should be able to do this with manager.update_definition() as well
lyr = gis.content.get('{your Feature Layer item id}').layers[0] lyr.manager.update_definition({ "timeInfo": { "startTimeField": "{your Start date/time field}", "endTimeField": "{your End date/time field}" } })
https://developers.arcgis.com/rest/services-reference/online/update-definition-feature-layer-.htm - This reference has plenty of other examples for Service Definition updates you can make with this function.
